10 years agoMax 10 Eval Kit - creating .pof file
The Max 10 FPGA Evaluation kit User Guide instructions for generating a .pof file (to burn into Flash) do not appear to match the menus I see on Quartus 15.01 lite. Does anyone have example setting...
10 years agoI am not sure this can solve your issue, it is not clear to me what you are doing so you are requesting to program a binary image of something external from quartus to FLash or ram? This can be done by convert programming file:
Click on menu File then convert_programming-files on the pane add your fles to be converted then hit "generate" than close. Your application for RF sintetiser in which language is written? How and what are you donwloading to MAX 10?
