VNH00
7 years agoMax 10 development kit installer
while running board test system (bts) warning "no JTAG cable detected or selected" I am running windows 10 pro with Quartus 16.1 installed. JTAG drivers installed and are visible in device manager ...
SreekumarR_G_Intel
7 years agoHello Viraj,
I assume you are using the Rev C board , Link below for the reference,
https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/max-10-fpga-development-kit.html
if so, can you kindly confirm the SW2 setting in the board ?
Thank you ,
Sree
VNH00
7 years agoYes the board is Rev. C and the SW2 positions are
- USER_DIPSW4 - position 0
- CONFIG_SEL - position 0
- VTAP_BYPASSN - position 1
- HSMC_BYPASSN - position 0
Thankyou,
- SreekumarR_G_Intel7 years ago
Did you get chance to try both the JTAG in the board ?
i.e i) using USB - Blaster and other one is JTAG header -> USB Blaster device connected externally ?
Can I also know you able to connect the device and detect but while run the BTS only you are facing this "No JTAG cable detected or selected " issue ?
Thank you ,
Sree
- VNH007 years ago
Yes I tried both the options and its the same warning "No JTAG cable detected or selected"
The problem is only when I run BTS, there is no issue if I just start programming the device in Quartus 16.1 programmer. Both the JTAG drivers get detected.
Thankyou,
Viraj
