jerry_anto's avatar
jerry_anto
3 years ago
LVDS SERDES RECEIVER
I'm trying to use LVDS SERDES intel ip for receiving LVDS signals and I have instantiated my ip from my top-module and i'm getting the below mentioned critical warnings.
I'm using a internal pll for LVDS RX which is not shown in PLL usage summary after i run fitter.
Kindly help us with a solution.
Critical Warning: The auto-constraining script was not able to detect any instance for lib < LVDS_RX_altera_lvds_core20_191_nwfh5si > core < altera_lvds_core20 >
Critical Warning: Make sure the core < altera_lvds_core20 > is instantiated within another component (wrapper)
Critical Warning: and it's not the top-level for your project
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    Is there error number for the critical warnings you observed? If yes, can you share it?
  • jerry_anto's avatar
    jerry_anto
    There is no error related to this critical warning.
      jerry_anto
      In this article ( ID: 000083063 ) it says the following,
      The problematic line in the pin_map.tcl file is in the get_p2c_c2p_clock_uncertainty procedure:
      set pll_atoms [get_atom_nodes -matching *${instname}|*:arch|*:arch_inst|*:pll_inst|* -type IOPLL]
      Resolution
      Open the pin_map.tcl file, replace *${instname} with *, and re-compile. The design should compile without the critical warnings.
      This issue will be fixed in a future version of the Quartus® II software.
      In my project files there no files named pin_map.tcl, is sdc_util.tcl the same as as pin_map.tcl ?
      I have another tcl file named *my_prj_name*.pdp_assignments.tcl which is generated from the interface planner since I have placed all my pins using that legally.
      Kindly clarify which is the tcl script that i need to edit the above mentioned workaround to remove my critical warning and place the pll.
    jerry_anto
    Is there any update on this chain ?
    Please update.
    AqidAyman_Altera
    Apologies for the late reply.
    Can you check between both the .tcl file you mentioned, which one has the following line:
    Then, you can try to change the *${instname} with *, and re-compile to see if it does resolve the critical warnings.
