14 years agoLVDS receiver resistors
I'm currently developing on a DE2-115 together with an HSMC daughter card (TI's ADS58B18EVM through HSMC-ADC-bridge adapter). I need to use LVDS I/O standard for interfacing the cards, so I know I ha...
14 years ago --- Quote Start --- I added a DDRIO_in megafunction to interfacing the ADC chip.Pin IN[5:0] and INCLK are from ADS62P29 and SIGNAL_TAP_CLK is used in the signaltap clk. --- Quote End --- You cannot probe at the DDR inputs, you need to probe at the DDR block outputs, i.e., the half clock-rate data. Cheers, Dave
