LPDDR2 External Memory Controller Using Altera Cyclone V GX Dev Kit video is corrupted
Hi Frank,
No worries. I remember seeing some of the full version some years ago, I should have snagged it then.
Much Thanks.
MikeZ
Hello MikeZ,
Yes the video is corrupted.
What is the question that you have at your side?
Adzim
- MikeZ11 months ago
Hi Adzim,
Thanks for your reply, basically I would like to use the ddr2 memory on my board to buffer data without the use of Qsys, the video in question I had hope it would have helped with this. If someone else has a copy of the uncorrupted version of the video it would be great if they could share it with me, failing that an example writing and reading a block of data to and from ddr2 memory.
Much Thanks
MikeZ
- AdzimZM_Altera11 months ago
Hello MikeZ,
I did try to look for the video source but cannot find it.
If someone got save the video before then it might help in this case.
I find this example project for 4 port LPDDR2 memory interface for the Altera Cyclone 5 GX Starter Kit :https://github.com/csus-senior-design/ram_int_4p/tree/master
Please have a look if the example can help you to use the LPDDR2.
Adzim
Hi Adzim,
Much thanks for your reply, I will check out that link today.
Much Thanks
MikeZ
