MikeZ
11 months agoLPDDR2 External Memory Controller Using Altera Cyclone V GX Dev Kit video is corrupted
Hi All, The tutorial video at: https://www.intel.com/content/www/us/en/content-details/649233/lpddr2-external-memory-controller-using-altera-cyclone-v-gx-dev-kit.html is corrupted, it will not pl...
FvM
11 months agoHi Mike,
sorry, I didn't look at the 2 minutes point. I believe the video file is simply cut after 2:06
- MikeZ11 months ago
Hi Frank,
No worries. I remember seeing some of the full version some years ago, I should have snagged it then.
Much Thanks.
MikeZ
- AdzimZM_Altera11 months ago
Hello MikeZ,
Yes the video is corrupted.
What is the question that you have at your side?
Adzim
Hi Adzim,
Thanks for your reply, basically I would like to use the ddr2 memory on my board to buffer data without the use of Qsys, the video in question I had hope it would have helped with this. If someone else has a copy of the uncorrupted version of the video it would be great if they could share it with me, failing that an example writing and reading a block of data to and from ddr2 memory.
Much Thanks
MikeZ
