MBarn13
7 years agoLow Latency 100G MAC not producing light through Mellanox MMA1B00-C100D optical module in Stratix 10 Transceiver Signal Integrity Kit
I am attempting to use the Low Latency 100G Ethernet Intel Stratix 10 FPGA IP Core on the Stratix 10 Transceiver Signal Integrity Kit but am unable to communicate with the board. I am using a Mellano...
SengKok_L_Intel
7 years agoHi Sir,
For the LL 100G Ethernet IP design example, you can refer to the following link to create/generate it for the S10 Transceiver SI kit.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-dex-s10-ll-100gbe.pdf
To isolate the problem, please try to turns on internal serial loopback and see if it can transmit and receive packet? Besides, if possible, please use a QSFP loopback module to perform the loopback.
Regards -SK
