AGuth
7 years agoLinux terminal turns unresponsive as soon as the FPGA is programmed ( DE0-Nano-SoC , Atlas-SoC)
Hi, I'm using a Atlas-Soc (DE0-Nano-SoC) from the altera university program. It has a Cyclone V FPGA with a HPS in-built. I usually connect to the Linux running on HPS through serial terminal (Pu...
AGuth
7 years agoYes, I'm booting the HPS first to Linux before configuring the FPGA. The HPS boots as soon as i power the device, is there a way to stop this or postpone the boot process?
I'm using the JTAG Quartus programmer to program the FPGA.
EBERLAZARE_I_Intel
7 years agoHi,
Have you try enabling the bridges?
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/embedded/2016/how-and-when-can-i-enable-the-fpga2sdram-bridge-on-cyclone-v-soc.html
I would also suggest you check this link, which have a lot of information on Programming FPGA, Booting Linux etc2:
https://rocketboards.org/foswiki/Main/GettingStarted
Select Cyclone V> your Quartus version> topic that you are interested in.
Regards.
