IKras5's avatar
IKras5
6 years ago
Linux for Arria5 build problem
I tried to build Linux for Arria5 board.
The https://rocketboards.org/foswiki/Documentation/GSRDCompilingLinux procedure fails with error “ERROR: Layer meta-altera-refdes is not compatible with the core layer which only supports these series: warrior (layer is compatible with zeus)”
The https://github.com/robertofem/CycloneVSoC-examples/tree/master/SD-operating-system/Angstrom-v2013.12#4---compile-and-u-boot-kernel-and-root-file-system fails also - seems to be outdated and has broken sources.
Could you provide operable procedure for building linux and rootfs for Arria5 ?
Ilya
  • IKras5's avatar
    IKras5
    the design is built on Quartus 15, but the problem is that the recipes do not work. I tried to reproduce the build from the Rocketboards page and it fails. Do you have updated build instructions / recipes ?
