14 years agoLine_VALID timing from D5M camera
Hi guys,
I am using the demo code of D5M on DE2-115. And I didn't change the camera settings in I2C_CCD_Config, in which Width = 800, HBMIN(horizontal blank) = 500, PIXLCLK = 50MHz. So the length of Line_VALID signal should be 800 + 500*2 = 1800, correct? But when I monitored the signal of Line_VALID,I found that: time Line_VALID = 1 is 16 us, which equals 800 pixels. This is meaningful but time Line_VALID = 0 is about 31.1 us, which equals around 1555. But I though it should be 2*HBMIN = 1000. Can you tell me which part is wrong? Thanks very much! BTW: The default settings for D5M camera are: EXTCLK (MHz) 50 Col_Bin 1 Row_Bin 1 Col_Skip 1 Row_Skip 1 Col_Size 1599 Row_Size 1199 Shutter Width (SW) 1984 Horizontal Blanking 0 Vertical Blanking 25No RepliesBe the first to reply
