Kindly provide us the following requested details as soon as possible. End Customer : F5 NETWORK Flex Manufacturing Site : Guadalajara (Mexico).
ITEM NUMBER
FFV1J-ICS-0718-00
FFV1J-ICS-0958-00
FFV1J-ICS-0972-00
FFV1J-ICS-0984-00
FFV1J-ICS-0989-00
FFV1J-ICS-0999-00
DESCRIPTION
IC,GB ETHER CONT,9X9MM,QFN64
IC 8 SPEED,27X27MM,FBGA672
IC, UF50, ALTERA, FBGA2397
IC, E+H-TILE, F50, FBGA2397
IC,PLAT CONTROL,FCBGA1310
IC, CONTROLLER,FCBGA1310
MPN
WGI210AT SLJXQ (MM#925131)
10M40DCF672C8G
1ST280EU2F50E2VG
1ST165EU2F50E2VG
EY82C627 SR3HG (MM#957627)
EY82C627 QS6B, 999DL8
DESCRIPTION MATCHES WITH MPN (YES/NO)
PLEASE PROVIDE CORRECT ORDERABLE PART NUMBER
STATUS (ACTIVE OR OBSOLETE OR NRND)
IF NRND, PLEASE PROVIDE LTB AND LTS DATE
IF OBSOLETE SUGGEST EXACT DROP-IN REPLACEMENT
PACKING TYPE (TAPE & REEL, ROLL,TRAY,TUBE AND BULK)
MPN IS AVAILABLE IN TAPE&REEL (YES/NO)
PROVIDE CORRECT ORDERABLE MPN FOR TAPE&REEL
MSL (MOITURE SESNSITIVITY LEVEL)
SMT (YES/NO) (SURFACE MOUNT/THROUGH HOLE TECH)
PACKAGE TYPE/CASE SIZE
ROHS COMPLAINTS (YES/NO)
PART MARKING
SHELF LIFE (IN DAYS)
DATA SHEET-LINK / PDF FILE
- NurAiman_M_Intel
Thank you for contacting Intel Community.
Please give me sometime to check and gain all of the information. Thank you.
Aim
- NurAiman_M_Intel
Apologize for the delay in response as we just received the required info for the queries.
Please be noted to post a separate forum case for different product as it will be answered by different team. Below is the answer for only FPGA product, for other product, please make a new post in the forum with the correct product families.:
10M40DCF672C8G-Active
1ST280EU2F50E2VG-Active
1ST165EU2F50E2VG-Active
10M40DCF672C8G- Tray
1ST280EU2F50E2VG- Tray
1ST165EU2F50E2VG- Tray
Please contact our distributor for more details
Kindly go to the link below for MSL:
https://www.intel.com/content/www/us/en/programmable/support/quality-and-reliability/msl.html
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an353.pdf
10M40DCF672C8G- FBGA
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_overview.pdf (Page 5)
Please be noted that Intel FPGA is compliant with RoHS (EU) 2015/863. You can find the related information from the following link:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/component/2019/does-intel-fpga-compliance-with-restrictions-of-hazardous-substa.html
PART MARKING
send in private message
Please note that Intel devices has the shelf life of 36months (per JEDEC J-STD-033B.1). Please refer to the ADV document below.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/pcn/adv1818.pdf
10M40DCF672C8G- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf
Stratix 10- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/s10_datasheet.pdf
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/s10_tx_overview.pdf
This the only info that can be provided here. Thank you.
Aim
