VGovi4
7 years agoJTAG programming not working properly in DE1-SoC Board
Hi, I have code which instantiates a particular design N no. of times. When the N>12000 , even though the Quartus tool generates the bitstream, I am not able to configure the FPGA on board(DE1-SoC)...
YuanLi_S_Intel
7 years agoHi Vidya,
By right it shouldn't be like this. The board will not reset itself unless it is designed so in the FPGA design. You mentioned about N>12000. What about the programming for N<12000? Is it successful? If it so, it might be due to your design problem.
YL
- VGovi47 years ago
Hi YL,
For n<12000 the FPGA programming happens as expected. In my design there is no logic of resetting . Infact I am not using HPS part of the device only PL part.
What I observed is for n>12000 the resource utilization goes above 50%. Will that cause a problem?
Vidya
