VGovi4
7 years agoJTAG programming not working properly in DE1-SoC Board
Hi, I have code which instantiates a particular design N no. of times. When the N>12000 , even though the Quartus tool generates the bitstream, I am not able to configure the FPGA on board(DE1-SoC)...
YuanLi_S_Intel
7 years agoHi Vidya,
First of all, may i know which programming file you are programming into the FPGA? SOF or JIC?
Secondly, do you power cycle the FPGA after you have programmed the new bitstream?
YL
VGovi4
7 years agoHello,
I am using .sof file for programming and I am not power cycling after programming. Do you know the reset condition for this board and where it is mentioned?
I am suspecting the board is resetting and then programming the FPGA in default mode which is from the flash.
Vidya
