12 years agoJTAG chain not seen unless factory_load switch is set
Can't figure out how to recover ... I tried adding the Flash Controller and programming the FPGA Flash and User Application Flash vie the update portal on the Arria V start Kit card. It se...
12 years agoThanks Dave,
I will work on it as a second priority. Here is the URL http://www.altera.com/products/devkits/altera/kit-arria-v-starter.html which will point you to a picture as well. As you say, the System Controller MAX® V 5M2210ZF256C4N device and I was not aware that it had internal FLASH. The FLASH consista of 2 x 1Gb Intel FLASH components which share USER, Factory FPGA configurations, NIOS executable code and some other items.
