12 years agoJTAG chain not seen unless factory_load switch is set
Can't figure out how to recover ... I tried adding the Flash Controller and programming the FPGA Flash and User Application Flash vie the update portal on the Arria V start Kit card. It se...
12 years ago --- Quote Start --- Is there a way to dump the FLASH image so I can compare it with the other Arria V Starter Kit card I have ? --- Quote End --- Just erase it? At that point the board will not configure, and you should be able to use JTAG. Cheers, Dave
