12 years agoJTAG chain not seen unless factory_load switch is set
Can't figure out how to recover ... I tried adding the Flash Controller and programming the FPGA Flash and User Application Flash vie the update portal on the Arria V start Kit card. It se...
12 years agoIf the device is configuring at power-on and somehow disabling JTAG, you could try holding the nCONFIG pin low, and that will keep the device in reset ... but I think still let you access it via JTAG.
Cheers, Dave
