TLu4
6 years agoJAM STAPL player for MAX 10 device 10M25DCF256C7G
1) unknown commands: 0x3F2, 0x3F4, 0x307, 0x002, 0x004, 0x03E Unknown addresses: 0x480008,0x500008,0x6C48A50F 2) Using JAM STAPL Player downloaded from Intel website, without changing any timing p...
ShafiqY_Intel
6 years agoHi TLu4,
Actually there is some issue with JAM STAPL player (quatur_jli command-line executable).
If you refer picture above, only certain Quartus and JAM STAPL player version combination is pass (pass means able to program without failure).
For example:
- You not using real-time ISP (Uncheck), you are using Quartus 16.0 version to generate JAM/JBC. And you are using JAM STAPL player 16.0 version. Thus, the results is pass (able to program without failure).
- You not using real-time ISP (Uncheck), you are using Quartus 18.1 version to generate JAM/JBC. And you are using JAM STAPL player 16.0 version. Thus, the results is failed/error (this Quartus and JAM STAPL player version combination did not have in above picture).
In conclusion, only version combination in picture above able to program in JAM STAPL player successfully.
I hope this will help.
