SLice's avatar
SLice
7 years ago
Issue with the usage of Arria 10 (10AX115N3F40E2SG) development kit (bittware)
I bought A10PL4 development kit with Arria 10 (part no : 10AX115N3F40E2SG) from bittware in March 2018. I am trying to run some sample code with PCIe interface included on FPGA. However, I am unable to load any new bit file on FPGA as PCIe virtual hot swap option is not working as expected with bittware software / drivers. I would like to know whether intel can provide driver / software to use this specified development kit.
  • JohnT_Altera's avatar
    JohnT_Altera
    ​Hi,
    I would recommend you to contact Bittware on the board related issue.
  • SLice's avatar
    SLice
    Hi John,
    Thanks for your response. It seems there is no hardware issue in the board, however with the PCIe driver.
    I would like to know the possibility to get the drivers / supporting software from intel, while using the bittware hardware.
    JohnT_Altera
    ​Hi,
    The PCIe driver is usually come with the board as it is depending on what design is being implemented.
    Please let me know which particular design and driver you are using, if you are getting it from Intel.
    • SLice's avatar
      SLice
      Hi John,
      I am looking for,
      a) PCIe X 8 Support.
      b) PCIe virtual hot swap support.
      c) DMA 4 bar access.
      d) PCIe minimum memory address space 255 MB
      e) Vendor id - 0x12ba
      f) Device id - 0x55
    • SLice's avatar
      SLice
      Hi John,
      PCIe ip configuration for FPGA has already been done. I would like to get the supporting driver files for CPU, to detect the FPGA card as PCIe device.
