Issue with quartus_pgm Command-Line .jic File Programming on DE0-Nano (Ubuntu 24.04 + Quartus Prime
error message suggests that default flash loader image isn't loaded. I'm not using command line version of quartus programmer, but shouldn't the programming command include option I "Initialize Bridge Device", e.g. -o PI;myfile.jic ?
Hey FvM,
So sorry for the late reply!
That tip about adding -o I to the quartus_pgm command? That's brilliant! I've been stuck on that "Flash Loader IP not loaded" error, and your idea about explicitly initializing the bridge device totally makes sense as a way to fix it.
I'm gonna go try programming with the -o PI; option right now. I'll let you know how it goes ASAP!
Thanks again for your help!
- Xiaoxiu1 year ago
Thanks a lot for the tip! The -o I option was exactly what I needed. It fixed the "Flash Loader IP not loaded" error.
It's working now! Really appreciate your help.
