14 years agoIs this a broken segment?
When I packed up the board it was fine and it passed tests but now it seems that one segment has a bad joint or something since it won't light up (it's the fourth one from the right): http://i.sta...
14 years ago --- Quote Start --- These things happen. It might need to be baked. You could write some quick code to tie the output of that segment to a switch. It'll be on all the displays in that 4-pack but you'll know. --- Quote End --- Thank you for the reply. Could you elaborate a bit? I'm a newbie and I have some code that is supposed to control the segments but I have little hope of it working since it doesn't pass the test the board makes when it is turned on. What does "baked" mean?
