Theja
2 years agoIs there any option to generate 100MHZ clock without PLL in max10 device
In our project the external oscillater clock is connected to DPCLK pin max10 cpld. When I try to generate clock using ALTPLL ip .I am getting error like we can't use this pin to drive the PLL clock i...
AqidAyman_Altera
2 years agoCan you confirm the following information for me to check further on this:
- What is full OPN of the Max 10 device that you used?
- What is the DPCLK pin name?
- What is the error message that you obtained? You can copy the message and put here.
