Is there any example of compiling with a library (.a) file on SoC?
- 8 years ago
I found the clue here: https://developer.arm.com/docs/100070/latest/image-structure-and-generation/specifying-user-libraries-when-linking
You can use the
--library=name
option to specify static libraries, libname
.a.
So - even though the actual filename is libpth.a - however the build tool only works if I say it is: pth
the tool adds the lib at the front and the .a at the end, and will not countenance the user supplying the full (and valid!) filename!?!?!
good grief.
You can use the
--library=name
.a.
good grief.
