Rink
8 years agoIs there any example of compiling with a library (.a) file on SoC?
On the windows7 PC, the compiler is: 'Invoking: GCC C Compiler 4 [arm-linux-gnueabihf]' I am trying to use Pth, and I can certainly configure and make it on the de10-nano itself, however the libpth....
- 8 years ago
I found the clue here: https://developer.arm.com/docs/100070/latest/image-structure-and-generation/specifying-user-libraries-when-linking
You can use the
--library=name
option to specify static libraries, libname
.a.
So - even though the actual filename is libpth.a - however the build tool only works if I say it is: pth
the tool adds the lib at the front and the .a at the end, and will not countenance the user supplying the full (and valid!) filename!?!?!
good grief.
Rink
8 years agoI should note that hello_world compiles fine and targets down onto the de10-nano - but of course it is only a single source file. How to incorporate big lumps of 3rd party code (such as a static library) is what I am missing.
