SATC
6 years agoIs there any document about the Cyclone 10 GX data transmission with ethernet cable?
The software that has been used is the Quartus Prime 19.3 edition. Is there a tutorial or a document about it?
- 6 years ago
Your enquiry is too generic.
Couple of suggestion for you.
If you are looking for IP solution then you can checkout below Ethernet IP solution or Transceiver IP user guide doc.
- https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/ethernet-support.html
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/ug_cyclone10_xcvr_phy.pdf
Else if you are looking for some reference design for Cyclone 10 GX then checkout below link
or you can also google for some Ethernet training material to pick up the knowledge.
thanks.
dlim
Deshi_Intel
6 years agoHi,
thanks.
dlim
