13 years agois it possible to use c language to control ethernet after added it from pluggin
is it possible to use c language to control ethernet after added it from pluggin can i use c language to send data through ethernet without use CPU from SOPC ? which IP parts are minimum r...
13 years agoyes
no the TSE core. You can avoid a PLL if you already have a clock with the right frequency.
