Is it possible to have more than one avalon ports on external memory interface IP (DDR3) of CYCLONE 10 GX ?
Hi senjd,
The multi-port front end and its associated fabric interface provide up to six command ports, four read data ports and four write-data ports. Each port can be configured as read only or write only, or read and write ports may be combined to form bidirectional data ports. However, the multi-port front end (MPFE) are available only in the Arria V and Cyclone V device families.
As suggested by @sstrell, you can connect multiple master to Avalon slave in Qsys to configure your purpose.
Thanks @sstrell for the reply.
NAli1
Hi NAli,
Can you please explain what you meant by "read and write ports may be combined to form bidirectional data ports."?
do you mean simultaneous read and write is not possible?
- NurAida_A_Intel7 years ago
Dear SBilg,
"read and write ports may be combined to form bidirectional data ports." means that you can perform the data transmission in both direction ( read and write) but not at a same time.
Yes, you are right on the 2nd statement. Simultaneous read and write operation is not possible.
Hope this clear.
NAli1
