mfora1
6 years agoIs it possible to establish a serial communication between host Pc and a Cyclone iii using the usb port on the board (De0 terasic) ?
Hi everybody, I' m using a De0 board with a Cyclone iii FPGA; I need to feed data( 16 bit ) from my PC to a block-ram inside the FPGA. Is it possible to use the same usb port used to configure the FP...
JohnT_Altera
6 years agoHi,
It is possible. You need to include JTAG to Avalon Master IP and connect it to block ram for you to update the 16bit data.
