Is it possible to automatically boot a Cyclone V to the Application Image at power up in a Remote Update system.
Hi John,
yes it is possible. You will need to select the page to boot during quartus design. You may refer to the user guide below for the setting and method.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altremote.pdf (Page 21)
Thank You
- JBoot16 years ago
I'm not seeing anything in the user guide about controlling the page select at initial power up. The page you reference defines the method to set the location upon triggering a re-configuration using the core very clearly, but nothing about at initial power up. If it exists, I would think that would need be some type of option in the quartus or the convert programming file window, wouldn't it? After all any initial parameter settings are unknown to the FPGA until the bitstream is read.
John
