LFahem
7 years agoInterconnects resources on Arria 10 FPGA
Hello, I am working with an Attila board on which is installed an Arria 10 FPGA component. In the Arria 10 handbook, there is a diagram of the LAB structure which is atteched below. I want to know w...
sstrell
7 years agoIf you disable the hyper-retimer in S10, you've removed one of the key advantages from that device, so I don't trust that number at all.
Length of wires is really not something a designer typically needs to concern themselves with unless, as I said, you start running into congestion issues. Turn on the hyper-retimer and try again.
