hv2220
5 years agoIntel Cyclone V SOC Development Kit
I’m currently using the Cyclone V SoC Development kit. I’m using this board to generate 3 different 300MHz clocks. I’m trying to use the HSMC port (with a HSMC-SMA adapter board). Based on the inform...
CheepinC_altera
5 years agoHi,
As I understand it, pin AG2 is DIFFIO_TX_B16p. It is recommended for you to cross check with you HSMC to SMA card schematic to clarify. If this is an input, then you may trace from your HSMC to SMA card on the compatible pin for clkout.
Note that if your HSMC to SMA card only have the SMA routed to the transceiver channels, you might need to look for other card with the right routing for your target application.
Chee Pin
