hv2220
5 years agoIntel Cyclone V SOC Development Kit
I’m currently using the Cyclone V SoC Development kit. I’m using this board to generate 3 different 300MHz clocks. I’m trying to use the HSMC port (with a HSMC-SMA adapter board). Based on the inform...
CheepinC_altera
5 years agoHi,
In your assignment Editor, you only specific the pin location for the transceiver pin. Then run the Fitter compilation. You can check the assigned IO standard and termination at Fitter report.
Please let me know if there is any concern. Thank you
- hv22205 years ago
I did what you said (with regards to pin assignments). However, I'm still getting the same error.
Also, according to the pinout, Pin (P4-P3), (M4-M3) seem to be dedicated to transceivers(according to the the schematic and what quartus is showing).
I'm also attaching the schematic file and the project.
I just need to generate 3 clock signals from this FPGA, with each clock having 33% duty cycle and a phase difference of 33% from one another
I'm attaching my project as well.
