leondietrich
5 years agoIntel Agilex F-Series dev kit cant be programmed by JTAG
Hi, Im officially out of luck. After wasting an entire week on trying to get the programmer to work I posting my question within this forum.
I've got multiple bit stream files I'd like to use for ...
- 5 years ago
thanks a lot for your help! We've fixed this issue now. One thing we'd like to share, for a potential future reader, is that in addition to the above mentioned article one needs to completely erase the flash prior to configuring. Our working solutions looks like the following:
- Power off the board. Waiting for the caps to be drained doesn't seam to be necessary.
- Set MSEL[2:0] to ON/OFF/OFF
- Power on the board.
- Erase the boards flash using the programmer tools
- Set MSEL[2:0] to OFF/OFF/OFF
- Programm your *.sof file.
It's also required to leave the JTAG chain in the default configuration while erasing the flash. Last but not least: If step 8 fails retry a couple of times until it stops failing (we usually don't need more than 3 tries). It also seams to be more reliable (programming fails less often) at 24MHz than 6MHz, which the programmer defaults to anyway.
YuanLi_S_Intel
5 years agoHi Leon,
Can you try to change SW1.1 to ON as per suggested? Any update on this?
leondietrich
5 years agoHi,
As requested I checked if setting SW1.1 to ON is improving anything. The only difference it made was that it's now failing consistently at 14% instead of 13%. It's still failing with the timeout error from the JTAG server.
