Intel Agilex F-Series dev kit cant be programmed by JTAG
- 5 years ago
thanks a lot for your help! We've fixed this issue now. One thing we'd like to share, for a potential future reader, is that in addition to the above mentioned article one needs to completely erase the flash prior to configuring. Our working solutions looks like the following:
- Power off the board. Waiting for the caps to be drained doesn't seam to be necessary.
- Set MSEL[2:0] to ON/OFF/OFF
- Power on the board.
- Erase the boards flash using the programmer tools
- Set MSEL[2:0] to OFF/OFF/OFF
- Programm your *.sof file.
It's also required to leave the JTAG chain in the default configuration while erasing the flash. Last but not least: If step 8 fails retry a couple of times until it stops failing (we usually don't need more than 3 tries). It also seams to be more reliable (programming fails less often) at 24MHz than 6MHz, which the programmer defaults to anyway.
Can you try to use the previous programmer version that you are using? Also, try to remove the other devices in the JTAG chain and remain only the agilex.
- leondietrich5 years ago
Hi, Do you mean Quartus 20 with "previous programmer version"? Also, according to the documentation provided by Intel the second device in the chain (the MAX 10 fpga) can't be removed from the chain. All other available DIP switches only add further devices to the JTAG chain.
