Intel Agilex F-Series dev kit cant be programmed by JTAG
- 5 years ago
thanks a lot for your help! We've fixed this issue now. One thing we'd like to share, for a potential future reader, is that in addition to the above mentioned article one needs to completely erase the flash prior to configuring. Our working solutions looks like the following:
- Power off the board. Waiting for the caps to be drained doesn't seam to be necessary.
- Set MSEL[2:0] to ON/OFF/OFF
- Power on the board.
- Erase the boards flash using the programmer tools
- Set MSEL[2:0] to OFF/OFF/OFF
- Programm your *.sof file.
It's also required to leave the JTAG chain in the default configuration while erasing the flash. Last but not least: If step 8 fails retry a couple of times until it stops failing (we usually don't need more than 3 tries). It also seams to be more reliable (programming fails less often) at 24MHz than 6MHz, which the programmer defaults to anyway.
May i know which SOF bitstream you are using in the design example? Can you create a simple SOF file with simple input and output initialization and program and see?
Meanwhile for the warning message regarding to CMF, it can be safely ignored.
Thank You.
bruce
from the BTS we've tried bts_config.sof and qsfpdd_xcvr_nrz_25gbps.sof as well as the GPIO example. The Bitstream we've provided above (Have a look inside Hello_World.tar.xz), initializes the I/O and toggles the GPIO and QSFP leds at 1Hz. Besides writing a bitstream generated by the golden top example, I'm out of Ideas what could be more simple.
Also I observed that sometimes, the first JTAG timeout error message occures prior to the 209060 message indicating the start of the programming process.
