Intel Agilex F-Series dev kit cant be programmed by JTAG
- 5 years ago
thanks a lot for your help! We've fixed this issue now. One thing we'd like to share, for a potential future reader, is that in addition to the above mentioned article one needs to completely erase the flash prior to configuring. Our working solutions looks like the following:
- Power off the board. Waiting for the caps to be drained doesn't seam to be necessary.
- Set MSEL[2:0] to ON/OFF/OFF
- Power on the board.
- Erase the boards flash using the programmer tools
- Set MSEL[2:0] to OFF/OFF/OFF
- Programm your *.sof file.
It's also required to leave the JTAG chain in the default configuration while erasing the flash. Last but not least: If step 8 fails retry a couple of times until it stops failing (we usually don't need more than 3 tries). It also seams to be more reliable (programming fails less often) at 24MHz than 6MHz, which the programmer defaults to anyway.
Can you check the following?
- Have you tried to program the agilex with a simple design with SOF bitstream?
Thank You
- leondietrich5 years ago
Hi, Thanks for your help! We've also tried to configure the FPGA with an SOF bitstream, reassembling a fairly simple (a 4 bit shift register enabling one QSFP and GPIO led at a time, powered by a clock divider in order to make the blinking human visible, the HDL code itself is known to be working). We've also tried the sof bitstreams provided by the example projects. None of those worked either. - leondietrich5 years ago
I don't know if it's relevant but we're getting the following warning when trying to program said test-bitstream (which I've attached to this message for reference purposes):
Warning(19729): Current CMF data structure hash (0x15CD440C) is older version than latest CMF data structure but still allowable.
This might be transition period. You should update your CMF to latest version with hash { 0x8AC9CBBA } [ACDS 20.4 Release]- dsigner5 years ago
I observe the Warning(19729) as well.
- Mengjie5 years ago
It should have something to do with Quartus compatibility issue from 19.x to 20.4, which means you probably fail to configure FPGA SOF 20.x again if FPGA has been configured with 19.x image right after power cycle. For devkit, it usually has an image in ASx4 flash for power-on boot-up, so if the AS programming file JIC file generated by 19.x, then it probably runs into FPGA 20.x SOF file configuration issue later on after power cycle. So there are two options to go, one is to erase ASx4 flash with Programmer, the other one is to set MSEL to JTAG only mode. BTW, please do use 19.x Programmer to configure 19.x SOF file, same to 20.x SOF file, otherwise, it may run into configuration issue as well.
