MBiga
7 years agoINTEGRATED USB BLASTER ON DK-DEV-10M50 doesn't work whereas regular JTAG does
Hi, I would like to know if there is a way to reset/reprogram the integrated USB blaster integrated to this dev kit. It worked once at the very beginning I use this card, but doesnt work anymore w...
MBiga
7 years agoAnand,
So where we are now :
Config is SW2.4 ON and others are OFF.
When I do an Auto-detect, FPGA is found so as VTAP10.
I had the file I have just compiled, and it fail to program .sof file.
.pof file is programmed the right way and FPGA works fine.
Board clock controller is okay, board testsystem as well.
After testing this feature, I try again with sof file which now seems to work...
Indead everything look okay.
Thanks for your support.
Fabrice
