Inquiries regarding 10M08 Evaluation Kit FPGA
Hello, I am EJ, a researcher at KIST (Korea Institute of Science and Technology).
I am planning to purchase an FPGA to be used in the TDC Chip I designed. I am sending you an email with a few questions.
Currently I have the 10M08 Evaluation Kit.
1) My TDC outputs are 30 in total and output at 1.2V. I want to receive the output from the FPGA, create a histogram, and output it to the computer.
Also, I would like to create a circuit within the FPGA and use its output as an input to the TDC Chip.
2) Looking at the data sheet of 10M08SAE144C8G, it says that there are 40 GPIOs. Can I use this to input the output of my TDC chip to the FPGA??
3) If the kit I have cannot perform the parts I mentioned above, could you recommend another FPGA?
Thank you for your help
1 Reply
- WZ2
Hi EJ,
Judging from your description of the input quantity, it is possible. But to be more precise, I need to clarify what the data format of your histogram looks like, or what data format you expect it to be output in,
WZ
