14 years agoInformations about DUAL XAUI TO SFP+ HSMC BOARD/BCM8727
Hello, I wanted to ask, if anyone has more informations about how to use the DUAL XAUI TO SFP+ HSMC BOARD, especially the BCM8727 and its registers. I'm using the DE4 Development Board an...
9 years ago --- Quote Start --- Hello, I have a Stratix V GX Development Board and I've successfully used one SFP+ interface on channel 2. --- Quote End --- Slightly diverting the conversation here... I have a Stratix V GS (Stratix V DSP) development kit and the Terrasic Dual XAUI TO SFP+ development kit. The example project provided by Altera for 10Gbe uses the Statix IV development kit and a custom QSYS component which combines the 10Gbe MAC and the XUAI. Please could you briefly outline the steps you had to take to build the MAC and PHY for your Stratix V. For example, did you use the example custom QSYS component and modify it or did you just grab all the bits and pull them together yourself? If the answer is the latter I will have more questions :) Thanks!
