10 years agoIncreasing range Highspeed AD/DA Card
In order to decrease the range of the ADC (I'am using the Highspeed AD/DA Card hsmc model) we found in the data sheet of the adc manufacturer that you simple need to reduce the supply voltage. Is ...
10 years agoHello,
sorry for the long delay how ever let me explain: -We would like to increase resolution and thererfore decrease the range> (also wrongly mentioned in first post i'm sorry for that) -in the data sheet ( http://www.analog.com/media/en/technical-documentation/data-sheets/ad9248.pdf ) --- Quote Start --- The input range can be adjusted by varying the reference voltage applied to the AD9248, using either the internal reference with different external resistor configurations or an externally applied reference voltage --- Quote End --- Now my questions is can we vary this reference voltage in a proper way in the Highspeed AD/DA Card hsmc model? Best regards, Bert.
