10 years agoIncreasing range Highspeed AD/DA Card
In order to decrease the range of the ADC (I'am using the Highspeed AD/DA Card hsmc model) we found in the data sheet of the adc manufacturer that you simple need to reduce the supply voltage. Is ...
10 years agoThanks for your reply.
In order to clarify: *)Basically the thing i trying to do is decreasing range to increase resolution: (this was maybe not correct mentioned in my introduction post sorry for that) *)In the datasheet of the manufacture (http://www.analog.com/media/en/technical-documentation/data-sheets/ad9248.pdf) of the adc chip is mentioned the following --- Quote Start --- The input span of theADC tracks reference voltage changes linearly. If the ADC isbeing driven differentially through a transformer, the reference... page 20 of 48 --- Quote End --- so I suppose the by varying the source voltage I'm able to change range (and so to change resolution more bits for less voltage => I would like to use them with smaller signals) The question is now can I do did in a proper way on the Highspeed AD/DA Card board? (http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=67&no=278) Best regards. Bert.
