matif's avatar
matif
7 years ago
Inconsistent Data on UART output terminal from Sockit Cyclone V SoC board
With reference to my case (case no. 04274941) (https://forums.intel.com/s/question/0D50P00004OYyjkSAD/inconsistent-data-of-transceiver), I am having inconsistent data onto my UART output terminal (PUTTY on Windows 10 host machine). I have checked my design using Quartus 2 Signal tab logic analyser and my HDL results are perfectly fine. My Transceiver is running on 62.5MHz clock while I am running Linux on my cyclone V SoC board and I think that the Linux application that I wrote to read data is running much slower. Is there any way to see the consistent transceiver data. You can see whole progress of my work and discussion here (https://forums.intel.com/s/question/0D50P00004OYyjkSAD/inconsistent-data-of-transceiver)
  • Hi,
    May I know what is the Linux application that you wrote to read the data or did you get it from an example somewhere?
    Regards.
    • matif's avatar
      matif
      Hi, thank you so much for your answer. I wrote my Linux application in C language. It is attached herewith. I am accessing UART Output terminal using PUTTY on Windows 10 with baud rate 57600. Here are Details of my Linux operating System that I am using on my cyclone V board Linux : Poky 8.0 (Yokto Project 1.3 Reference Distro) Kernel Version: 3.7.0 Sent from Mail for Windows 10
      • matif's avatar
        matif
        Hi
        Thank you so much for your follow up. Everything is fine now. You can close this case.
