Hetvi
3 months agoin MAX 10 Dev kit
Hi Altera Community, I am encountering a JTAG Server Error Code 35 when attempting to program my MAX 10 Development Kit using the USB-Blaster. Below are the details of my setup and the issue:...
AqidAyman_Altera
2 months agoHi,
Error 209053 ("Unexpected error in JTAG server — error code 35") is a JTAG server communication fault, and it typically surfaces together with Error (209040): "Can't access JTAG chain," which can be caused by a download cable problem, TDO not connected properly, a noisy TCK signal, or TDI shorted to GND.
Refer here: Error: Cant access JTAG chain
I can give you the suggestion on the step-by-step troubleshooting as below:
- Check physical connectivity and board power first.
- Verify TCK signal integrity.
- Try a different USB-Blaster cable.
- Check for a JTAGServer service conflict.
- Check for the virtual JTAG device on the JTAG chain.
- Check for a JTAG Secure mode conflict (if applicable).
- Check cable driver installation.
