14 years agoImporting .csv files for DE1 pin assignments
I'm using the DE1_pin_assignments file for a design, and I used the board port names (SW[0], etc) in the design, but when I try to import the .cvs assignment file (Assignments - Import Assignments) I...
14 years ago --- Quote Start --- Thank you for the advice about exporting a .csv file from the project. Once I realized this was accomplished by using the File Export command with the Pin Planner open, rather than "Assignments - Export Assignments, I got the .csv file. It is formatted very differently than the one that came with the boards, so I should be able to figure it out from here. Thanks again. --- Quote End --- I'm glad you figured it out. Once you have your project working, come back and look at the scripts, you will find they are more convenient than using the GUI and importing .csv files when rebuilding projects in newer versions of Quartus. Cheers, Dave
