14 years agoImporting .csv files for DE1 pin assignments
I'm using the DE1_pin_assignments file for a design, and I used the board port names (SW[0], etc) in the design, but when I try to import the .cvs assignment file (Assignments - Import Assignments) I...
14 years agoThank you for the advice about exporting a .csv file from the project. Once I realized this was accomplished by using the File Export command with the Pin Planner open, rather than "Assignments - Export Assignments, I got the .csv file. It is formatted very differently than the one that came with the boards, so I should be able to figure it out from here. Thanks again.
