14 years agoImporting .csv files for DE1 pin assignments
I'm using the DE1_pin_assignments file for a design, and I used the board port names (SW[0], etc) in the design, but when I try to import the .cvs assignment file (Assignments - Import Assignments) I...
14 years agoBy the way, if you do not like the way I have used scripts, then you can create your own set of pin constraints from my basic design. Run the synthesis script to create the example design, and then use Quartus to export a Tcl script or .csv script for the pin assignments, eg., use Project->Generate Tcl File for Project.
Cheers, Dave
