14 years agoImporting .csv files for DE1 pin assignments
I'm using the DE1_pin_assignments file for a design, and I used the board port names (SW[0], etc) in the design, but when I try to import the .cvs assignment file (Assignments - Import Assignments) I...
14 years ago --- Quote Start --- I didn't see anything in the zip file that was helpful (not a sample .csv file for example) --- Quote End --- Please read the readme.txt file, and then look at scripts/synth.tcl. That file creates a project and synthesizes the example design. The scripts/synth.tcl script calls procedures in scripts/constraints.tcl. That file contains all of the pin constraints. At a minimum, if you use the same top-level pin names in your design, you can use the Quartus Tcl console and
tcl> source scripts/constraints.tcl
tcl> set_default_constraints
Ask questions if you need clarification. Cheers, Dave
