8 years agoImplementing adc on cyclone 5
implemented the module according to manual i was able to run the program successfully but i am not able to find the output may be i assigned the pins in wrong way can anyone suggest me to which pi...
8 years ago --- Quote Start --- implemented the module according to manual i was able to run the program successfully but i am not able to find the output may be i assigned the pins in wrong way can anyone suggest me to which pin i should assign the following adc_sclk and adc saddr , adc cs and adc sdat thank you --- Quote End --- This depends on what board you are using. Refer to the manual provided by the manufacturer (likely Terasic). They list all the FPGA pin connections for on-board devices.
