NKuma51
7 years agoI'm not able to program the external flash device (which stores the FPGA configuration programming file) with the FPGA programming file (.jic file) using USB blaster II, JTAG and Quartus Prime standard edition 16.1.2 software.
Note that I'm not using the intel/altera recommended external flash device in my project, I m using something similar from different manufacturer. Is instantiating the Serial Flash Loader IP inside...
NKuma51
7 years agoHello, Thank you so much for the response. I will try this out. Could you please also let me know if instantiating the Serial Flash Loader IP in my top level Verilog file is mandatory? In other words, can I just program the external flash device using the .jic file through the JTAG interface and FPGA and USB blaster II (without worrying about instantiating the serial flash loader IP)?
