cosx
6 years agoIgnored Buffers in Delay Line Design
Hi everyone, I am currently designing a delay chain using Cyclone V and come across a strange problem. The design in verilog is shown below: module delay_chain(delay_in,delay_out); input wire de...
KhaiChein_Y_Intel
6 years agoHi Mingqiang,
Could you share a simple test case for investigation? What is the software edition and version you are using?
KhaiY
cosx
6 years agoHi KhaiY,
Thank you so much for your help!
May I ask the test case here you refer to is simulation or real test on board?
If it is simulation, I have done RTL simulation using Modelsim, but does not show any effect on delay. (I guess this is due to failure of low level simulation in modelsim)
The software edition is Quartus Lite 19.1, do you think the Lite Edition is not that smart to map the code into the hardware?
Thanks!
Mingqiang
