IC FPGA - EP4CE40F23C8N -Urgent
IC FPGA - EP4CE40F23C8N has a maximum number of single-ended digital inputs/ outputs of greater than 700 where in this context, the maximum number of digital inputs/outputs is also referred to as the maximum user inputs/ outputs or maximum available inputs/outputs, whether the integrated circuit is packaged or bare die.
- FvM
not sure what your actual question is. You are asking about a specific FPGA device in F484 BGA package. According to device overview document, it has 324 user I/O pins available. Same die is also offered in F780 BGA package with 532 user I/O pins. For detalis of pin functionality you can refer to pinout tables.
Frank - Martin_11
Please clarify on whether the product has a maximum number of single-ended digital inputs/outputs of greater than 700?
Please clarify whether the product has an ‘aggregate one-way peak serial transceiver data rate’ of 500 Gb/s or greater?
- FvM
Neither.
324 < 700
EP4CE series has no GBit transceivers at all.
- AqidAyman_Altera
The answer is no. Please refer to the link below for the device's handbook.
- AqidAyman_Altera
I wish to follow up with you.
Do you have any more questions on this?
- AqidAyman_Altera
I hope the previous response was sufficient to help you proceed. As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
